restoration scania LBS 141
Re: restoration scania LBS 141
Inläggav arvevisnes » 14 mar 2015, 22:45
Fantastic restoration. :o
Where did You buy rear steel mudguards?
arvevisnes
Inläggav kent häggdahl » 16 mar 2015, 19:22
Ja, där kan man tala om tålamod och energi...
Jag borde också gjort dendär proceduren med rambyte,men.. :wink:
I do have a question to Mr Javantilborg,
Is one of your fueltanks for sale, mine is not useable ??
Keep on working..
Best regards Kent H
kent häggdahl
Inläggav janvantilborg » 19 apr 2015, 17:38
arvevisnes skrev:Fantastic restoration. :o
I bought the fenders at Daf / TRP.
but I have the last of this type.
but they still have these http://www.trp.eu/nl/Trp/Parts?key=subG ... value=9965.
grt Jan
janvantilborg
Inläggav janvantilborg » 19 apr 2015, 17:49
kent häggdahl skrev:Ja, där kan man tala om tålamod och energi...
Keep on working..
Best regards Kent H
I have two tanks originally for my own.
but I still have two tanks of an army Scania dimensions 40x40 but I do not know the length out of my head. these are for SALE
grt Jan
janvantilborg
Inläggav kent häggdahl » 20 apr 2015, 18:58
Thank you for the offer, but i already found one useable nearby...
Best Regards Ken
kent häggdahl
Inläggav janvantilborg » 26 apr 2015, 17:05
an update again after some time.
the body is as good as done.
rear side finished, and succeeded pretty good if I do say to myself.
fixed the body on the chassis.
the place where the trailing axel enters filled with a few bar
after various attempts to bend the headboard is not entirely successful. the left upright is right but the rest. unfortunately not
so I decided to make a few other there.
a pair of strips whipped around to fasten the wings.
after a lot of measuring and trailing axle jacking and another fit and look we got them last Saturday still mounted.
the tank applied to measure. and I also make the coffin supports already . but that's for next time.
janvantilborg
Inläggav Per Thomson » 29 apr 2015, 08:56
Ok, thanks a lot for your report! :D
Inläggav janvantilborg » 07 jun 2015, 11:38
Here some pictures of the progress and there are a lot I think.
body is as good as finished.
So now on to the chasis
tilt lines sanded.
a few Saturdays ago several spots sprayed with primer and painted several parts that I've made like tank straps and the passions etc. then could begin building.Bild
tilt pump dismantled because it was leaking again
made steering.
chassis brought the painter. just look at his site (http://www.gpnieuwkoop.nl)
tanks ready to spray.
tires ready to assemble.
and now can start building ..
janvantilborg
Inläggav Per Thomson » 07 jun 2015, 22:40
Tanks a lot for your report! :D
Inläggav janvantilborg » 06 sep 2015, 14:02
Here some pictures of the progress of recent times.
it is not much but better than nothing.
I made the fuel lines, and the bogie motor geinstaleerd, now have the wiring to check and repair.
attached the photos
janvantilborg
Inläggav Per Thomson » 07 sep 2015, 10:22
Thanks again, nice work!
How about the diesel tank, was it useable without repair?
Inläggav Noxcania » 07 sep 2015, 23:06
Imagen not having a digital camera...
(& by the way; geinstaleerd = reinstalled)
Inläggav janvantilborg » 22 nov 2015, 22:54
a small update.
again done a lot of different things.
but just look at the pictures
The body is ready, and went to the blaster and now he stands inside a barn
chassis put in the wash, and the wiring harness mounted bogie lift connected.
cabin emptied, again i found a pile of rust
Now I'm working on the engine and so far it looks good.
janvantilborg
Inläggav Per Thomson » 24 nov 2015, 15:27
Thanks again!
